Wire...
goose5741
So i need some wire for my amp, and probably big 3...i was just gonna buy a bunch of 2 ga to do it all with. Is the welding supply 2 gauge wire actually 2 gauge???? Is there any other cheap 2 awg wire I should know about? I don't feel like getting stuck with 8 gaughe with a 1/2 inch jacket on it, I also don't need anything fancy, just the cheapest 2 gauge possible... Need about 30 feetish.
You can use 1/0 terminals for 2 gauge.
You can also use 4 awg terminals, just spread em out, then use a vise or a good strong clamp to shut it. Fits more snug than 1/0 connectors... i like to melt an assload of solder in my terminals, makes them more rigid and probably helps lower resistance at the terminal.
i just found a 2awg kit but not so sure its much larger than my 4awg. if you can just go 1/0. otherwise PM me i'll sell you my 2awg kit cheap
What kind of 2 awg kit did you find the only one i've ever seen is the PA one and it's really 4 awg....All i need is wire and a fuse holder/fuse so i'm not gonn a bother with a kit.
goose5741
goose5741
DUBUQUE, IOWA
goose5741
Mike Mccabe
