Enclosures materials
kombat96
I was wondering what you the forum would recommend on using for the build of a solid box. its going to be a sealed enclosure.
3/4 mdf right. now what type of screws and glue do you recommend. i was thinking along the line for glue the titebondIII or the gorilla glue. what do you think.
for the screws 1 5/8" coarse threaded drywall screws, place the screws 4 to 5" apart and counter sink all screws.
please let me know what you guys think. and if iam wrong or you can suggest something better please let me know.
as if you couldnt tell yes i am a noobie...lol so please be kind.
i use 3/4 MDF and good wood glue. i use and brad or nail gun instead of screws and clamps. u only need air nails to hold the wood in place while the glue dries. but if u dont have a air nailer corse dry wall screws about 1 5/8 long are fine
Depending upon the power it Sounds like you got the plan my man. Make sure all your cuts are straight, so that your panels fit together flush. It will make your glued up joints strong as they could possibly be. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
3/4 mdf
titebondIII
sounds like you read the last 10 threads on building a box //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Its a bit on the drill that makes a "gouge" for the screw head to sit below the surface of the wood. Makes for a cleaner look.
Its not a must, i didnt do it.
Titebond II is cheaper, so i bought it instead of Titebond III
Gorilla glue is even more expensive
kombat96
kombat96
michigan
supa_c
