kickerlivinloud
Banning survivor
Ok to cut the cost of my system I am building my enclosure completely my self. I have it custom designed to my trunk so it is really hard to explain what it looks like. B/4 any type of dissplacement I have come up with about 6 cubs of space. I am hopeing that with the diss. of the wood, driver, and port it will be closer to 5 cubs. My main problem now is trying to figure out how much port area I need. Using the caculators over at loudspeakers101 I have gotten this info...
http://www.loudspeakers101.com/VentCal1.htm
Minimum Diameter = 15.05 inches
Minimum Area = 177.98 inches
Length of a side for a square vent = 13.34 inches
This is all for an 15" sub with 38mm Xmax tuned at 45Hz. What I want to do is either make a plug or and extention to lower the freq. to 28Hz for daily driving. Should I use a 13"X13" inch port or should I make it smaller. I am totaly new to the actual install part of car audio so bear with me. If so, how can I make a plug/extentsion to reach the 28Hz????
I am open to ideas...
Your input is appreceated...
Jon
Jon
