Enclosure Questions
ap0091
I purchased a Kicker CVX15
1000W RMS/ 2000W MAX
hooked up to a kicker zx750.1 amp
Its in a ported enclosure that has these specs (inches)
16.5 Depth
21 Inch width
15.5 Height
Port
1.5 Width
14.5 Height
What difference would it make if i got a bigger enclosure?
If this box was sealed, the volume would be 2.36
Model CVX15
Size (IN.,CM) 15, 38
Impedance (OHMS) 2 or 4 DVC
Max Rec Amplifier Power (WATTS PEAK/RMS)* 2000/1000
Sensitivity (dB 1w/1m) 91.6
Frequency Response (Hz) 18-500
Mounting Depth (IN.,CM) 8-1/2, 21.5
Mounting Cutout (IN.,CM) 13-13/16, 35
Min Rec Sealed Box Volume (CU. FT., Liters) 1.8, 51.0
Max Rec Sealed Box Volume (CU. FT., Liters) 5.2, 147.0
Min Rec Vented Box Volume (CU. Ft., Liters)** 3.0, 85.0
Max Rec Vented Box Volume (CU. Ft., Liters)** 5.0, 142.0
this is what kicker recommends and you are not even at the minimum recommended enclosure size for your sub, just imagine how good it would sound if it was built in the middle of what kicker recommends.
ap0091
ap0091
East Texas
power-fanatic07
