Enclosure positioning in SUV
Ali1
e6300 FTW
I'm debating on having the enclosure (pair of L7s) subs up port back, but my tailgate seems to be taking it in the ***, considering how close the port is to the rear. I was thinking subs and port on same panel. Would i yeild better results keeping the first approach or get equivalent results with subs/port on same panel in an 04 blazer(almost like having a wall by having subs and port facing the front). Anybody ever did extensive positioning in an SUV? The reason i ask is because i'm planning on a new enclosure, but undecided on subs/port placement..
Thanks in advance!
ive always been told its best to have the subs up and port to the rear/hatch... i personally have had 2 13w7s in a box like that n it hit hard... Current box i have is sub and port on the same side... havent tested it yet. when i do ill let you know.
I had my JL sub with port on same side as sub, pointing to the hatch and it sounded good.
Now I have 2 10's sealed and not sure which way to go. Ima try flipping them up towards the roof tonight, and see if it makes a difference.
I can't fit 2 15" hdc3 below the window doin sub up port back...so instead I just finished a box that is subs/port up....I heard it works nice in the trailblazer....and btw my box is going in an 03 trailblazer
robinson said:
with subs up it soundz louder outside but nasty bass.with subs to the rear longer nice smoother bass
each suv is differant...and I would rather do port up instead of smothering the port to the rear if space is an issue, Just make sure you have the space. Most people do subs up in SUVS anyways...
Ali1
e6300 FTW
Ali1
U.S.
JeepSound
michigan born
    May 14, 2026
michigan born
    May 14, 2026
