Enclosure design needed for 1 - 12"
deez283
Tinkered around a bit with RE's enclosure caculator but seems I'm not get enough port area. Figured I'd try here and see if anyone could help..
The sub Orion HCCA 12d (old version) 1999/2000
Box size and tuning 2.50 after sub dispacement tunned to 33hz
Area to work with 13.5 tall x 38 wide x 14 deep... would like to double baffle the front.
Not much room to work with but thought I'd try.
thanks in advance.
you should put the box at 31in wide 21in depth and 12.5in height with a 4in port and a 10in port2 piece in the box, it would be tunned at 33hz with like 2.5cf after sub placement, and also put the sub on top of the box not on the side if you read the orion manual it says to put them facing up or down
what will this be going in? That will help with sub/port placement. As for the manual... they didn't even fallow that with there own custom HCCA box LOL
With your h x w x d and a double baffle I came up with around 2.978 for air space. Then you have to figure port and sub displacements. (this is with 3/4" wood)
lol that and the fact that that sub only needs 2cf to get loud.... i have done several of them with anywhere from 1.6 to 2.2 and they get plenty loud on 2500 rms //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif beast of a sub too weighs over 70 pounds and shits all over anything in its class..
and it will never survive unless it is face up or down...
This thread is almost a year old fellas. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
noticed that lol. fail my my part haha
i dont have a BS excuse like pro-rabbit :p
I thought about running two 1 inch dowels, top to bottom and side to port side. I am going to run 2 baffles, so will be 1 1/4" thick front.
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
702
deez283
deez283
Aberdeen, WA
DonH
    May 18, 2024
    May 18, 2024
