Enclosure design for Hertz subs
ml²
Hi Guys,
I'm turning to you for some assistance in designing a box for two 12" Hertz 300 subs. I did build a sealed enclosure as per the recommended specs but find the sound "messy".
The sub specs are:
D mm 253
Xmax mm 14
Re Ohm 2,9
Fs Hz 33
Le mH@1kHz 1,83
Le mH@10kHz 0,56
Vas lit 49,62
Mms gr 167,1
Cms mm/N 0,13
BL T-m 13,57
Qts 0,47
Qes 0,53
Qms 4,40
Spl (1m/2,83V) dB 90
The max outer dimensions of the area in my car are:
Width - 31"
Height - 16"
Depth - tbd
I'm hoping someone could offer a ported/vented design.
The subs will be powered by the sub channel on my 5 channel amp, Audison lrx 5.1k
Thanks in advance
I'll take a look at the specs, but I can't imagine vented sounding less "messy".
Maybe try a few blocks of wood in each chamber to reduce the available space;
ie reduce the size of the sealed enclosure. See if that tightens things up. In the
mean time I'll look at the specs and make a box recommendation based on my
opinion.
You could do 5 cubes at 30-34hz with 75 sq" of port area. That is a really
large box for most medium to small cars.
Here's 5@34hz
Thanks for the reply.
If you don't mind looking at the specs that would be great. Keep in mind I only have 31" width and 16" in height to play with.
I can build the box, but when it comes to the calculations I have no idea.
Thanks for the reply.If you don't mind looking at the specs that would be great. Keep in mind I only have 31" width and 16" in height to play with.
5 cubes @ 30-34hz is what I came up with after looking at the specs.
I had edited that post later that day.
ml²
ml²
Toronto, Ont
mcsoul
