Enclosure design for 16 8's
Rawr-DQ
!!!!Vote Third Party!!!!
Looking at a clamshell design.
Considering doing it for my own.
However. The mouth, I can only get about 8x33.5....=268"s Surface area.
The speakers have a surface area of 804"s......16 8"s.
Any idea on how well it will work?
The final specs will look like this:
Re = 3.37 ohms (4 ohm nominal)
Fs = 34.9 hz
Qes = 0.5323
Qms = 6.93
Qts = 0.4943
Vas = 7.6 L
BL = 13.3 N/A
Mms = 127.7 grams
Cms = 162 um/N
Xmax = 12mm one-way linear (70% BL method)
Rated RMS Power = 200 watts
Depth = 4.25"
OD w/ gasket = 8 5/16"
Cut Out = 7"
Sealed Box:
0.280 ft^3 w/ F3 of 50 Hz (Qtc = 0.707)
Ported Box:
0.60 ft^3 tuned to 30 Hz
F3 of 25 Hz
Someone that knows something about this please chime in! I am curious to know some things about clam-shells since it is more than likely going to be my next setup as well.
BTW how much power are you going to be running to the 8's?
I will be running 1 or two sundown 3000D's
soo... anywhere from...
I can wire them to 1 ohm, or .25 ohms. or 4 ohms
8000 watts/ 500 each @ 1 ohm strapped
3200 watts/ 200 each @ 4 ohm strapped
kill 1 amp @ .25 ohms and get maybe 5000? with 312.5 per speaker.
Run 1 amp @ 1 ohm, and get 3000 / 187.5 to each speaker.
Rated 200, has been run 400, and burped at possibly 800.
Rawr-DQ
Rawr-DQ
Fort Myers, FL Posts:____________31,337,666,999
MikeyB
NorthFramingham
    Jun 30, 2026
