elevation audio dx1500.1 (zenon baord aka saz1500d v1 )
infamous_e46
hArRy_DaNgLeRs
26,366
California
elevation audio dx 1500.1 same board as saz1500d v1
minty in og box
$300 shipped conus or best offer or trade for smaller amp and cash
Old Elevation Spec. Sheet:
2042 @ 13.8volts
LPF-35-300hz
SSF-10-60hz
Bass Boost-0-18db
Phase Shift-0-180degree
Freq-10-350hz
Input-200mv-6v
signal/noise ratio-105db
Thd-.01%
Efficiency-86%
Fuse rating-30ax4
Power- DC 14.4v negative ground
Operating Voltage- DC12v-17v input
Dimensions- 256(w) x 61(h) x 434(l) mm
Google convert: 10"W X 2.4"H X 17.1"L
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
96
infamous_e46
hArRy_DaNgLeRs
infamous_e46
California
infamous_e46
    May 24, 2024
    May 23, 2024
