electronic problem
  • Thread starter pfunk358
  • Start date
  • Replies 5
  • Views 530
P
pfunk358
Guest
in my car i running the bd1500.1 and the mtx152 for amps in my car there prob. drawing aroud 1800 watts right? i also have 2, 2 farad caps and an optima yellow top battery.. with 4 guage power wire... but my head lights are still dimming... i have checked and double checked all the wiring everthing is wired right... do i need another battery or a hi amp alternator... also i was gonna put in another amp the RF 1000a2 but i don't think my car could handle it... what should i do to fix the problem
thanks
Your car has a small Mitsubishi alternator in it. You should look into a larger alternator or have that one rewound. Especially with running amps that size.
Definitely agree, you need a much bigger altenator. Stock altenators start having trouble around 250-300 RMS, some less than that. The only way to fix your dimming lights is to get a bigger altenator. So before you go out and just buy a bigger altenator, figure in how big you need it to be by figuring out the amount of watts you will be running. I think Zane will be able to help you out there, I think I saw a post a while back where he was talking about altenators.
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
https://www.caraudio.com/threads/all-bnib-focal-fdp-4-600-ds18-exl-p2500-1-sundown-audio-sfb-1000-4d-350x4-4ohms.614462/ :)
18
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
701
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Guest
Phatillusion
    May 23, 2024
    May 22, 2024
