electric up front 14.48 stays same rear drops below 12v
stereohead69
Ok this is probly a dumb fix ok my front battery both before and after the fuse read 14.48 volts the whole time I play my subs till the amp goes into protect in the rear I have 3 kinetik 2400s that read 14.48 volts as well untill I turn the bass up then they all drop below 12.00 volts sending the amp into protect I have tryed cleaning the same ground that I have used for years didn't help I tryed charging all batteries still nothing different I checked ohms they are still at about 1.28 so I don't know what it could be HELP ME PLEASE.
i suspect the amp ground is bad. to test this theory measure the voltage between the negative terminal at the amplifier and your negative battery terminal under your hood. if this value is not 0 or very close to it, then i would recommend running a full ground. whenever i run two or more batteries i always just run a full ground and the rear batteries need not even be grounded to the chassis. in other words all batteries are wired + to +, and in the same exact manner they are wired - to -.
stereohead69
stereohead69
oswego ny
PSturmer
