donpisto
Best explanation ever. Period!Let me try to put it in anoter way...
Spread your woman's legs. Where her feet/ankles are is where the left and right of the stage is. What you want to do is stick it right between her legs (center focus). If you're off to the left or right, you'll probably hit her thighs, but that's okay, because rubbing the inner thighs and arouse her, but dead center is where the spot is... for her and for you.
If you're very far off to where her feet/ankles are, then you're just ******* her toes or licking her ankles, which might get her going, but it'll do nothing for you... this is all assuming one leg isn't shorter than the other.
Lets say you want to raise your soundstage higher and ***** **** her. It'll be best if both her tits are the same size, then again, you want to sticking right in between...
Helotaxi, what you're doing is rubbing/poking her left thigh and caressing her left nipple. You might have a fetish for that, but it's not how she wants and needs it. Stop being selfish and give to her right.
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
See, I think the misconception people get is that it sounds better being that the VOCALS are in front of the driver. Here is what a few others are trying to say. Sure you have the vocalist directly in front of you and it sounds fine and dandy, louder if you must say (there is volume knob for that //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif), but what if you play a song where you have two vocalists? One on each side of the stage and then a third jumps in center stage.
You also lose what the artist is trying to deliver through their music. I have messed with Adobe Soundbooth and have seen the crazy things you can do with editing music and I got a glimpse of what some of those gurus do. Why does this matter? Because sometimes you have certain instruments that play in specific locations on the stage. It can be up higher than center stage or lower. It can also, more importantly in this situation, be further left or right. Maybe once instrument is halfway from the center to the left and another kicks in all the way to the left. With the center stage in the center of the vehicle, you will notice that difference. With it in front of you, you will not.
Wanna test it out? There is a track on the IASCA disc with 7 drums, see if you notice the spacing between them. If you hear 4 or 5 of them coming from the same spot, your stage is way off.
