does anyone know the real rating of this amp @ 2ohms? rated at 509w@20hms but at 11V
They weren't "designed" for a one ohm load, they are one ohm stable, that doesn't mean you have to run it at 1 ohm....Originally posted by FAM4LIFE It was designed for a 1-Ohm load. 1009 X 1. If you can get your subs down to 1-ohm then you straight.
No you don't have to run it at 1-ohm, but to get the most out of it. 1-Ohm is your best bet. The specs clearly show tha 1-ohm is the idea load for max power.Originally posted by snova031 They weren't "designed" for a one ohm load, they are one ohm stable, that doesn't mean you have to run it at 1 ohm....
Same with every single 1 ohm stable amp out there...Originally posted by FAM4LIFE No you don't have to run it at 1-ohm, but to get the most out of it. 1-Ohm is your best bet. The specs clearly show tha 1-ohm is the idea load for max power.
True. I see what you are saying. I think if its 1-Ohm stable why not use it.Originally posted by snova031 Same with every single 1 ohm stable amp out there...
Exactly, also less distortion. Just be cause an amp is 1 ohm stable does not mean its best suited to be run at 1 ohm, but who knows with the nine.1, hasn't even been released yet.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifOriginally posted by Matador yeah, their optimum output is at 1ohm which is 1009watts. But i feel like being nice to my electrical system n run a system at 2ohms rathe than @ 1 ohm. 1 ohm would draw more current than at 2 ohm .
Late spring-early summer, according to Loyd...Hopefully I'll have 2 of them come summer....Originally posted by Matador true true. when is it coming out?
just watch, edesign nine.1 is gonna be like the JBL1200.1, hype wise i mean. at least it's alreayd started here in caraudio.com
