ed amps
nazty tc
i was lookin to run 2 nine.2's one for the front id componets and one to my 12 eclipse only thing is will a nine.2 be enuff power to bump this sub its a dvc 4ohm i have it bridged @ 2ohms. and from what i can see the ed amp isnt 2ohm stable? i dont want the nine.1 due to power/ the eclipse is only rated at 450rms and 900 peak ... help here... lol
IF you must stay eD, the nine.1 would be the better choice of the eD amps. Just set the gains properly. Headroom isn't a bad thing.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i take it you dont like ed?lol i was lookin at the nine.1 but at 2 ohms its 900 watts.. i dont know if thes amps are underrated or not but that seems to be pushing the sub a tad hard.. i have a da3600.1 now goin to it and it hits ok think its only pushin about 300 so its a little low for the sub..dunno //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
I've used Avionixx amps, and still use one for my front stage(same build house). The eD amps are good, I just thought you wanted to stay eD. There might be more fitting choices somewhere else.. rated rms at 2 ohms.
The nine.1 will be fine, you just won't run it full power all the time, which will be a good thing! It'll leave room for upgrading/changing/adding a sub in the future w/o changing your sub amp.
I've used Avionixx amps, and still use one for my front stage(same build house). The eD amps are good, I just thought you wanted to stay eD. There might be more fitting choices somewhere else.. rated rms at 2 ohms.The nine.1 will be fine, you just won't run it full power all the time, which will be a good thing! It'll leave room for upgrading/changing/adding a sub in the future w/o changing your sub amp.
i am runnin a diamond audio 3600.1 to the sub for now i was debating if i wanted to switch to ed's or just get a 3400.2 to run my seprates.. i do want to keep amps the same brand etc..
nazty tc
nazty tc
worcseter
djman37
