Eclipse XA or Sony XM?
temuchan
Now I know that everyone thinks Sony's are bad, and I know a bunch of people think Eclipse is good, but the Sony has much higher rms numbers. Are the numbers hyped up or does the Sony really put out more power than the Eclipse?
Eclipse XA1000 - $140
4 ohms: 320 watts x 1 chan
2 ohms: 480 watts x 1 chan
http://www.sonicelectronix.com/item_10399_--+CLOSEOUT--+--+Eclipse+XA1000.html
Sony XM-D9001GTR - $150
550 watts RMS x 1 chan @ 4 Ohms
900 watts RMS x 1 chan @ 2 Ohms
http://www.sonicelectronix.com/item_7013_Sony+XM-D9001GTR.html
I''ve used the Sony XM-D9001GTR and it does not seem to be overrated, after all it is CEA Rated 550 watts RMS at 14.4 volts
Also, the Sony has an LED that tells you when the amplifier is being overdriven and the "distortion suppressor" is engaged (similar to a clipping LED) and that helps in setting gains and sending a clean signal to your sub(s).
As for the Eclipse XA1000 amplifier, I use the 2-Channel Full Range Class D version XA2000 and it pushes very clean 100 watts at 4-ohms to my MB Quart door speakers.
I also like the minimum alternator drain from the Eclipse XA amps and the fact that there is a Clipping LED that helps you set the gains is definitely a plus.
Just my $0.02, hope it helps
Get the Eclipse and you won't be sorry.
well the sony has a cool blue light!! i base my buys solely on BLING man! thats why i run all chrome audiobahn man! ALL CHROME SON!
  • Locked
COMPLETED WTB Eclipse SC8365
I checked at Diyma and I signed up for an account but I cant post in the classifieds. Thanks for the tip, I'll keep a check there.
I have a couple 3000s and 5000s and cant remember the other two right off hand, but these will not work with your unit that I can think of by...
881
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
temuchan
temuchan
mville, MI
DonH
maylar
    Jun 2, 2024
    Jun 1, 2024
