Eclipse DA7122(1 Channel Class D Subwoofer Amp)
Dirty101
4
Zone
I Got Some Question About The Eclipse DA7122(1 Channel Class D Subwoofer Amp)
500RMS@4ohm@13.8V
1000RMS@2ohm@13.8V
My Batt Volts Is Low 14's At The Amps Pow/Gro.
Does it do rated power?
Or more or less?
Needing To Know,So I Can Set My Gain.
Its has.
Low Pass Filter 50-200Hz
Subsonic Filter 1-60Hz
High Pass Filter 50-200Hz
I thought 1 Channel Class D Amps Didnt Have High Pass Filters.
Im Using A Single SoundQubed SDC 15'' D4 600RMS, In a 4cf.Net Tuned To 35Hz, I Listen To Rap,
So What Should I Set My Filters To?
What Are The ICEpower Amplification Modules?What Do They Do For The Amp?
I know I'm a little late, but to reassure you Eclipse rated their amps at 13.8v so it's not misleading. I used 4 7122's for about 8yrs each pushing a 9152. They will give 1300- 1400 no problem. Do not run them at 1 ohm though. Eclipse means it when they say only 2 ohm stable!
Dirty101
Dirty101
Zone
What was that?
michigan born
    May 14, 2026
michigan born
    May 14, 2026
