eclipse 8445 problem/question
fock, no blue/white wire on the harness. it looks like its been yanked out or something. is there anything else that could be used?
theres an orange/white wire labeled illumination. would that work? it would make sense since it would give a constant signal would it not?
no it wont work, best thing to do is tap into your radi fuse and run it off that. because that is switched which means it will only get power when your key is turned on. best thing to do is go to an auto parts store and get an inline fuse tap and run with that, they should know what it is. it will look like this http://www.nocablezone.com/images/fuse.jpg all you do is plug it and and read the instruction on what fuse to place where, then connect your remote wire to the wire coming out. boom theres your remote wire
You should be able to use the red acc. wire w/o problems if you dont have a remote wire.
what is that wires original purpose? because I already have it hooked up elsewhere. should I just crimp both wire together?
that looks like what Im going to have to do...this sucks
I know there is a Remote and a Power Ant. wire on that harness. You need to really check again. Take pics if you have to. We will gladly help you out.
yeah, originally I did have it hooked up to the power ant., but the remote wire is missing from the harness so now I am looking for alternatives
allout13
allout13
Georgia
allout13
