Eclipse 8445 install problem
paventi
hi i'm new to this site. i just installed the eclipse 8445 HU in my 2000 honda civc. After i connected all the neccessary wires and started the car the HU wouldn't power up. I checked the wires and everything was where it should be. I thought there was a problem with the HU. So i went back to the store and exchanged it. And when i got the new one i had the same problem... any suggestions on what it could be? thanks for your help!
installed incorrectly. Most likely a harness error.
Didn't the store power it up to see if it worked when you brought it back? does the stock harness have a ground wire? sometimes you have to run that wire yourself.
This year I had one harness that was making intermittent contact on a Eclipse cd player. We replaced the harness to solve the issue. The first thing that you need to do is re-install the factory radio, does it still work? Next meter the power and ignition lines to verify that you still have power on both. Ensure that you still have a good ground after that. This sounds 100% installation error.
paventi
paventi
montreal, qc
forbidden
NorthFramingham
    Jun 30, 2026
