ebay hid kit sucess??
look like they have a good amount of space to keep them cool, plus the glare shields are sealed on the front, which should appease some. the back looks like you may have to do a little modding to put wires through those screw caps, and keep them sealed, though.
yea i figured that but thats no big deal ..well im gona get2 sets from dmm ..still dunno if i want 34w 8k or 55w 8k..and will i need a relay for each set
ive heard so many mixed results and all these ballast amd bulbs ..someone point me in the direction of.a solid company...i will be running in low beams and fogs ....35w 8k or 55w 8k...i know you guys have used some of this stuff with sucess
I had a 35w hid kit for my fogs and lows from ddm with a relay on my lows. Within 2 weeks of getting them my driver side light would either wouldn't come on at all or would take a few tries to get it on. About a week later both bulbs on my lows blew out and my fogs ballast failed. There customer service is good but it is confusing.
so what would you reccomend?? what bulb temp did you have?
MORIMOTO like I said before. Ive ran a bunch of HID setups. I have retrofitted projectors in my car and truck. Go with morimoto. DDM *****. Everyone that says they are good is because they know no better. Kinda like when people come on here saying kicker in the best.. But they have never had anything else.
Dont go over 6000k.
So morimoto 35 watt 6000k.. Done.. (even though you should do a projector retrofit)
There ya go.
http://www.theretrofitsource.com/product_info.php?products_id=3955
BTW they dont sell anything over 6000k for a reason //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Dont go over 6000k.
There ya go.
H11: Morimoto Elite HID System - HID Systems from The Retrofit Source Inc
yea they morimots look nice but seem excessive since im not doing projector retrofit..i will be buyin 2 sets while.my fogs are projectors already
okay, when you go to 55watt, the biggest thing you have to consider is the heat. it's 50/50 that 35w will melt aftermarket housings, and some few cars even the stock. next, i think the only harness that i would trust even coming close to being good enough is from the 80's. not that it can't support the power, but there will be a great deal more resistance in the wire, and give "dirty" voltage by the time it hits the ballast. i would only ever run 55watters from battery power, via relay, of course. you could use one relay for both. as for putting hid's in "halogen" housings, it's really a matter of which housing. it doesn't have to be a projector. many, sport glare shields, that work fine, and all will need to be re-aimed. that right there is the #1 problem. the gas pocket is typically in a slightly different spot than where a filament would be, and they end up being high.
addressing the need for high-beams: high beams aren't called "high beam" in regards to the brightness, rather than the level of aim. put the same light in a high beam and low beam, and the high is always higher. even in a dual filament, the high beam filament is below and further back than the low, so reflection angles are higher, and narrower. definitely do the conversion, so that the low beam does not turn off on high, you will thank yourself when it doesn't go dark waiting for the bulb to warm back up. 35w is just fine for low beams unless you pick a higher color (also check what is legel in your area. 10k/k is the limit here.) i had 10's in mine, as is about the most popular around here, and then switched to 8k recently. the apperance still looked real good, (not much difference you can tell without sitting side-by-side), but the road visibility is night-and-day difference, especially in the rain. if you are unsure about the relay kit, just get it. i would always advise that. the only question is if you absolutely need it. if you want something to really reach out there, get driving lights (aka "fog lights")with glass projector lenses. they are not cheap, but they actually work. i spent $200 on mine at a steal.
oh, and fyi: to whoever stated that an insurance company won't honor a claim over h.i.d. lights, well, that has got to be one rare dikc head to do that. i've done insurance repairs, and out-done the insurance adjusters on the estimates many times.... since i owned all their same official books at my shop.... just this last year alone, i know of 2 different major companies that actually pay for new h.i.d. bulbs and/or kits if dirt gets on the bulbs, or any other minor damage to the lights, wires, and/or ballasts. i haven't done it for living for a long azz time, but i still know my way about the insurance co's..
so if i do decide to go 55w will i need 1 relay kit per set ...1 for lows and 1 for fogs?? or one per side?
that depends on the size of wore in the kit. also, if they don't use the standard 30/40a relay, need to make sure the relay they use isn't some tiny one. but normally, it's just 1 for high and 1 for low.
im still leaning towards the 55w ddm kit ...not sure of the quality wiring on their harness..it doesnt have those details
I have an $85 kit and a $35 kit. the $85 is better quality, but i had a ballast fail. It was replaced under lifetime warranty. The $35 kit has not failed yet but does not have a warranty either.
NASTY08IMPALA
NASTY08IMPALA
LOUISVILLE, KENTUCKY
NASTY08IMPALA
