rp69
Can this amp run at 1ohm daily. If it can what are the numbers . Will it overheat blow break down
It's not that good electrical makes below rated loads safer, it's that poor electrical would make a bad situation worse.Can anybody explain this theory that more batteries makes below-rated impedance loads somehow safer?
This is true with most amps. If you run them hard they'll demand the juice. If you don't have the juice, it stresses them out and forces them into a protection mode. Sometimes it'll protect, sometimes it's too much and it'll just blow them.Can anybody explain this theory that more batteries makes below-rated impedance loads somehow safer?
Going to have good electrical . Have come across guys doing this . But seems for copition. And with upgrades . Gust for purbs it seems like . But on the other hand herd they can run all day at 1ohms with out modifications. I herd but In a bigger fuse . Then good to go . So much different info is out there
