Dynamat, Cascade, Need Help ASAP
Mark_ab
The Alpha Male
What is the best stuff out there? Conversely, what is the best stuff for the best price? My trunk rattles something fierce, and it's annoying as hell when you can hear it inside the cabin. I was looking at some trunk kits, and I'd rather not spend over 90 bucks or so. Dynamat seems to be the best, but it is expensive. I was looking at a Cascade trunk kit as well. What are your suggestions? Thanks
I picked up 4 boxes of dynamat extreme off the internet for 90bucks a box for the 39sqft. cheapest I've seen them. I can barely hear the car on the expressway... and the sound quality is MUCH better. Every time i did a section i noticed a difference. Ie. trunk, inside floor, rear deck, doors, etc.
This is the place I purchased the dynamat from... Another thing I had done that reduced road noise and vibrations underneath the car is http://www.ziebart.com Underbody sound barrier. Not only does it help it prevents rust and has a lifetime warranty. I was power washing my wheel wells and some of it was coming off the plastic area ( it doesn't stick good enough to soft plastic ) I called them and they explained that every summer I can bring the car in and they will spray them again to keep the rich black look which also improved the the cars visual. I also had the doors done along w/ every inner body panel =) cost $260ish
Mailing Address Tricks-N-Tunes
P.O. Box 3688
Plant City, FL. 33564
Phone: 1-866-655-5900 (toll free in US)
Fax: 1-305-946-0216
DYNAMAT XTREME BULK PACK 36 SQ. FT. $99 Item # 1321559245 Ebay
both are good cascade i like better it is easier to work with...dynamat extreme made a big improvement but over all cascade has a product for every part of your car....price is an isue get dynamat if not get cascade both give a positive results.
Mark_ab
The Alpha Male
Mark_ab
Edmonton, Alberta
audiolife
randy hagan
    Jul 15, 2026
