DVC solobarics 1ohm vs. 4ohm??? HELP!
dpatt420
Ok so I took all of your advice that said a Kicker 1500.1 amp (2 ohm stable) would handle 1 ohm just fine. Well it does not. Protection kicks on at high levels.
I have 2 Solobaric 4 ohm subs. I was looking at the rockford fosgate wiring diagram and wired them up for a 1 ohm load. Well that didnt work so I am now looking at the diagram for a 4ohm load.
The sub sounded great before protection kicked in. How much of a difference will I notice changing the load to 4 ohm?
Biggest difference will be that the amp probably won't shut off when you crank it up...
You'll lose a couple dBs of output. Since the amp was going into protect it probably wasn't making a whole ton of power and thus the loss won't be huge. Good news is that the amp will run cooler.
dpatt420
dpatt420
Nebraska
audiolife
Mike Mccabe
