Duralast Platinum batteries?
possible they are re-badged, like diehard does with their platinum battery made by odyssey.
What are the specs on the battery?
Duralast Platinum AGM
PN: 34R-AGM
750 cca / 120 rc
Compared to my second choice...
Duralast Gold (conventional wet cell)
PN: 24F-DLG
750 cca / 130 RC
This is for a Prizm (Corolla) with a 500w RMS class d amp and eventually a ~200-300w RMS 4 channel later, 80A alternator, no other electrical add on accessories.
Group 34 is much larger than Group 24. if you have a 24 i doubt you can fit a 34.
This Group 25 may fit
PC1400 - Odyssey batteries
My Group 34/78DT (Odyssey PC 1500DT)
PHCA: 1,500 at 80°F (27°C)
CCA: 880A at 0°F (-18°C)
CA/MCA: 1,050 at 32°F (0°C)
HCA: 1,250A at 80°F (27°C)
Reserve capacity: 135 minutes
Short circuit current: 3,100A
Deep cycling capability: 400 at 80% DOD
Design life: 12 years
Typical service life: 6 to 8 years
Operation temperature range: -40°F
(-40°C) to 176°F (80°C)
High rate discharge:
1,500 amps for 5 seconds
1,280 amps for 10 seconds
1,170 amps for 15 seconds
1,100 amps for 20 seconds
Keep Hope Alive... Are you sure? According to Interstate's spec sheet... and my own measurements yesterday...
A 24F is 10 x 6-7/8 x 8-3/4
a 34R is 10 x 6-7/8 x 7-3/4 (Shorter)
A 25 won't work the terminals are on the wrong sides. The reason I want a 34R is they don't carry a 24F in the AGM line.
my bad, i suppose i should have looked at the right dimensions. not sure what i was looking at. thanks for correcting me!
I have decided to go with the Duralast Platinum 34RAGM. I have determined that it is relabeled Deka Intimidator 9A34R and I have not found any really negative reviews of them online.
Unless someone here thinks otherwise?
K_Watson
K_Watson
Indianapolis, IN
d77543020
