Dude.... Did I Get RIPPED
But why wouldn't it push the subwoofer AT all.... he said it hit hard in his car and i believe him off that same amp..... what if anythign should i do? The wiring is right?????
answer me this
1)The wiring is right or wrong????
2) The sub is probably fine?
3) What kind of amp should i look out for to power it?
I also have an alpine mrp F200 4 channel amp but i doubt it would be powerful enough or make any difference bridged to the sub
OK so my wiring is wrong (which would be a major problem) right?!
No the wiring is correct, your sub is a D2 which can turn into 4 or 1ohm. Since your amp is not 1 ohm stable its sees a 4 ohm load which gives it 200 rms. If u want to get the full 400 rms u will net to get sub that is D1 or D4.
Generally an amp makes more power at lower impedences. Wiring 2 subs would drop the impedence to 2 ohm, which produces ~400 watts from your particular amp. With 1 sub you're at 4 ohm...which is only ~200 watts.
so my sub can transform into a d4 or d1 and i need to get another d1 or d4 then get a bigger box for the two...... why don't i just get an amp for the sub that will work
Look for an amp thats 1ohm stable. Match the Rms from the amp to the RMS from the sub.
Bimmerdriver
Bimmerdriver
Santa Rosa, California
Bimmerdriver
