Wiring Diagram. Complicated. Need asap Help
Trying to figure out how to wire up this stereo and I really dont wanna mess it up so I thought Id come on here to clarify. Im trying to hook up 2 TXA 1000D amps to eachother (strapped become 2ohm) to a pair of single voice coil 4 ohm wild beast 15" woofers.
Heres the only pertaining diagram I can find in my manual for strapping the amps together and what the wiring would look like. It for a single sub and only 2ohm though.
Who can help me on what this is supposed to look like.
This was my best guess, slave + and - to master + and -, then + and - from each sub straight to the master....?
Nope. The owners manual pic shows the positive coming off one amp going to the positive on the speaker, and the positive from the other amp going to the negative on the speaker, while both negatives on the amps are connected together.
So to parallel 2 speakers in this configuration... run from the positive of one amp to both positives on each speaker, run the positive from the other amp to both negatives on the speakers, and then connect the two negatives on the amplifiers together.
The diagram also shows a 2ohm woofer, though, mine are 4ohm. Make a difference? Kinda lost
Two 4ohm woofers in parallel would result in a 2ohm (mono) load. If I understand how the 'strapping' works on those amps, each amplifier will see half of that load (1ohm to each amp).
bridge the speakers
+ speaker 1 to positive speaker 2
- speaker 1 to negative speaker 2
amp connections
+ speaker 1 to positive output of amp 1
- speaker 2 to positive output of amp 2
amp to amp
slave cable
wire from amp 1 - to amp 2 -
voila //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
After reading both those explanations I get 2 different versions of what would be right, which one is it? I'll try and make a new diagram of what I understand later if one isnt available
Thanks guys
Thanks guys
I believe its like this.
PuN
Hey WOT can you please reply to my messages or my emails I kept my end of the deal what happen to you?? I havent received anything yet please email me or send me a PM
WOT
Banned
WOT
Toronto,CANADA
nismos14
