Dual ported enclouser for two JL audio 12w6?
Hello, i have 2 jl audio 12w6 and right now i have a bandpass box that my cousin gave me. I have heard a lot of bad things about the badpass box so im trying to find a good duel ported box for two 12w6. If you go to the spec tab in the link it will tell you the measurements of a single ported box for the w6 but not the measurements for a dual.
12W6v2-D4 - Car Audio - Subwoofer Drivers - W6v2 - JL Audio
I reckon if you double the drivers, you double the box size.
No?
381
922
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
878
984
Nugg32
Nugg32
Ohio
slvrado28z
    May 24, 2024
