Dual Battery Questions
Since both will be located up front, and really all you are doing is providing a path for the secondary battery to be charged, really the 80 amp would work fine for your application.
I would go with the 200 amp though to be prepared for the future. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Yeah.. might as well just buy a spool of 0 gauge and do it all that same. At least if you decide that you want more power later on down the road you'll be prepared and you won't have to redo everything.
Well the think is, I have enough wire to do as planned. If I do 0 all the way through, I'll need another $50 worth of 0 gauge. I won't be going any bigger in this build. I'm a family man and have scaled way back..lol
764
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
783
883
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
tooshort_128
tooshort_128
Sterling, VA
tooshort_128
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
