Caps are a waste for pretty much every situation.
The remote on is going to be the problem. Your deck can't keep the voltage up with the current draw of both components. Run a relay for the remotes and you should be good to go.
Crap...
I bet I was about to run into this very issue, then. I plan to run turn on leads to a pair of stereo amps plus an electronic x-over, all spliced off my head unit's remote output. I think a nice, preventative 12v relay action is called for. Sweet - Rat Shack, here I come.
kingkong101, did this help your issue at all?
Betrayer for rwhp is low you should probobly check to see if anything is restricting your flow (cats clogged intake clogged with crap) open that thing up get a cai and if not long tubes an o/r x and flows and a good dyno tune that should get you to a healthy 20 wrhp increase.. Maybe even more if you are in fact being restricted.
Actually, on the stock dyno that was in my sig, if you do the math with a 15% drive line loss (typical for my 5-speed) you get HP at the crank of 266. The rating by Ford for my generation is 260. That is either an extra efficient *****, or a slight bit of factory-freakism. That is because the dyno-run was made just after I got my car, and it still had the stock paper air-filter on it even. I mean I hadn't done jack, yet.
Now, I have a K&N CAI (which came w/ a 9" diameter K&N filter element //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif ) and I have a MAC off-road H-pipe for power mods. I do not the H-pipe in ATM, as I found out CA has a $5K fine
per modified stock catalytic converter, and my car came with
4 of them. I will use the off-road H, but only if I have a spare $20K around to pay the fine if I get caught. //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif ...and the modulars can pass the sniffer part w/o cats, fyi.
I am not messing with any more power mods 'till the KB blower. I don't see the point. Just saving my pennies and biding my time...
...sure do look forward to it, though.
The Cobra guy has, pretty much, a pure driving issue. He is on 17" ~15-18psi 275 Nitto DRs. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Everyone tells him he has an 11-second car with a 12-second driver... he's used to it by now. I am sure he will pick it up. It is just sad that mine does 13-second runs and his are only in the 12s. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
