Dual alt guys?
sure why not. or you could run a second battery in your trunk and run 0awg to it from your second alternator, and then run your amp straight from that second battery. hows 200 amps dedicated for your stereo sound //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Err, the battery is back there, so how does it work with a charge coming in? The charging charge has to complete a circuit.
I'm just wondering. If I am completely wrong go ahead and correct. I never understood multiple alts.
I'd just run them in parallel.
We did separate charging systems for the vehicle, and for the audio system in Jason's... and it was just never... right.
Ran them in parallel, wonderful.
Also, trust Iraggi... especially on alternator information.
nG
Jumping the positive output lead of one alternator, to the positive output lead of the 2nd alternator, then connecting it to the positive lead on the battery.
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
nG
nG
OOOOOO, Gotcha.
Had to do a little grinding on the brackets to clear the alts. Still test fitting it all before I powder coat it.
Almost but without the frame off part. I probably should have just gone the extra step and pulled the frame out and done that too.
Indeed. Noticed that when I ended up looking at your thread.
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.
Good stuffs.
nG
Blazin_Jason
Blazin_Jason
Vancouver Isl, BC, Canada
bamaboy
vegang
vegang
