dual 4 wiring
ok the amp should have 2 speaker posts thats 2 pluses and 2 minus so you can wire each coil to a different + - terminal it will be giveing the sub 150 rms to each coil so 300 total rms for that sub
the amp does 600@4x1 bridged so am i not going to be able to give the sub 600watts? because if i cant give it at least 500 im gettin rid of the amp
should i cancel this amp before it ships?? the sub needs 5-600watts, and the only way this amp is going to give it that is in 4ohms bridged. its a dvc4ohm sub....can this work??
perfecxionX
perfecxionX
indianapolis
perfecxionX
