perfecxionX 10+ year member CarAudio.com Veteran 2,666 11 indianapolis Jan 17, 2007 #1 so a dual 4 speaker cant be wired at 4 ohm? if so i have an amp for sale Click to read more...
KidThump 10+ year member V.I.P 1,905 4 Georgia Jan 17, 2007 #2 A dual 4 ohm sub can be wired to 2 ohms and 4 ohms
OP perfecxionX 10+ year member CarAudio.com Veteran 2,666 11 indianapolis Jan 17, 2007 Thread Starter #3 so its not just 2 and 8? why are the diagrams not listed anywhere?
KidThump 10+ year member V.I.P 1,905 4 Georgia Jan 17, 2007 #4 so its not just 2 and 8? why are the diagrams not listed anywhere? Click to expand... is it 1 or 2 subs?
OP perfecxionX 10+ year member CarAudio.com Veteran 2,666 11 indianapolis Jan 17, 2007 Thread Starter #5 single....
KidThump 10+ year member V.I.P 1,905 4 Georgia Jan 17, 2007 #6 Wire it to 2 ohm......... The lower the ohm the more power the amp will push 2 ohm is the lowest u can wire 1 Dual 4 Ohm sub
OP perfecxionX 10+ year member CarAudio.com Veteran 2,666 11 indianapolis Jan 17, 2007 Thread Starter #7 so 4 is not an option
KidThump 10+ year member V.I.P 1,905 4 Georgia Jan 17, 2007 #8 so 4 is not an option Click to expand... yes it is if you wire just one voice coil it will be on 4 ohm
OP perfecxionX 10+ year member CarAudio.com Veteran 2,666 11 indianapolis Jan 17, 2007 Thread Starter #9 i already bought an amp thats on its way, so i just leave one of the sides completely alone?
KidThump 10+ year member V.I.P 1,905 4 Georgia Jan 17, 2007 #10 i already bought an amp thats on its way,so i just leave one of the sides completely alone? Click to expand... yeah if u want it on 4 ohm.....................What kind of sub and amp
OP perfecxionX 10+ year member CarAudio.com Veteran 2,666 11 indianapolis Jan 17, 2007 Thread Starter #11 sd2.515, zxi6006 -budget setup thanks alot bro
KidThump 10+ year member V.I.P 1,905 4 Georgia Jan 17, 2007 #12 sd2.515, zxi6006 -budget setupthanks alot bro Click to expand... Its cool if u need any more help let me know
dleccord 5,000+ posts CarAudio.com Veteran 6,051 9 Sacramento Jan 17, 2007 #13 that some big knockers. real big.
dumple 5,000+ posts What's in your trunk? 8,978 64 Philly Jan 17, 2007 #14 yes it is if you wire just one voice coil it will be on 4 ohm Click to expand... uhm u prolly should just use one coil if its dual 4 ohm?!?! u crazy
dumple 5,000+ posts What's in your trunk? 8,978 64 Philly Jan 17, 2007 #15 ok the amp should have 2 speaker posts thats 2 pluses and 2 minus so you can wire each coil to a different + - terminal it will be giveing the sub 150 rms to each coil so 300 total rms for that sub
