dual 4 ohms or single 4 ohms?
I would always get the dual out of the choice of single or dual 4 ohm. You can wire that dual into a 4ohm load, a 2 ohm load or with another dual 4 ohm sub later you could wire them into a 1 ohm load. It is all about options. Go with the dual ohm.
ok i got the single //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif. does anyone have any opinions on a good sub box for my set up?
Um....why not buy the dual and wire it into a 4ohm load? Then if he gets another amp some day in the future he will have options as to wiring it down or pairing it at a 1 ohm load if he happens to get a mono sub amp thats 1ohm stable. Why do you think a 2 channel will not run a dual 4 ohm sub wired at 4 ohm? I do it all the time.
/boggle........he has two ways to wire it as a single. either 4 ohm or 2 ohm, with another dual 4 ohm he could wire them at 4 ohm or 1 ohm.
If i remember right that amp will do around 450 at 4ohms. So why would he buy it and wire it into a 2 ohm load?
Sorry, maybe I'm missing something, but if it's a dual 4 ohm driver, that means it's 4 ohm + 4 ohm. You have two options in which to wire that. First is in series, which will give you 8 ohm. Second is in parallel, which will give you 2 ohm.
In checking with SSA's website, the DCON specs even list the Re as 7.8 ohm which is typical when you have a dual 4 ohm driver. They provide specs based on the driver being wired in series. The specs will stay the same when wired in parallel, i.e. 2 ohm, except that Re will change to something like 1.8 ohm.
you cant wire dual 4 ohm sub to 4 ohms final.... only 8 or 2 ohms:viking2:
mr. cook
mr. cook
bayport
rebelfromva
