dual 2 ohm or dual 4ohm?
how? sory to sound dumb. i have never done this
This is new for me as well, so let me try and explain the best i can.
On the Type R sub, there will be two areas to connect speaker wires...one on each side. On each of these connections, there will be a positive (red) and a negative (black) connection.
Let's call them RED 1, BLACK 1 (for the connections on one side) and RED 2, BLACK 2 (for the connections on the other side). You are going to run a wire from RED 1 to RED 2. You are then going to run another wire from BLACK 1 to BLACK 2. Now you are set to run wires to the amplifier (or to your speaker terminals on your box...which will then go to the amplifier). You will run a wire from RED 1 to the positive terminal on your sub box (which goes to the positive terminal on the amp) and you will run a wire from BLACK 2 to the negative terminal on your sub box (which goes to the negative terminal on the amp).
Since we're on this topic and i'm not meaning to hi jack the thread. i just thought i'd ask here and not start a whole new thread...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Can you hear a difference in the 2ohm and 4ohm Type R sub?
TIA
Rico
TIA
Rico
Definitely no.
paintballproam
Hey i can change this
paintballproam
troy nh
Psyence
