DSP + Amp. How many channels does DSP need to be?
  • 2
Rysandro
Ok I'm new to all this...
I have 6 speakers that I want to drive actively.
2x Tweeters
2x6.5 Woofers in Doors
2x 6.5 Woofers in tailgate
I plan on getting two PDXF-4 to drive all 6 speakers, this will leave me with 2 channels available for one of the PDX4 incase I decide to go 3-Way Front stage in the future.
The question is do I need a 6 input/output channel DSP to have all 6 speakers active?
Or does it not matter how many input/output channels the DSP Is since its esentially a Pre Amp and its the PDX-4's that will truly power the speakers?
I ask because I like the price of the Audison Bit 10, but it's listed as 4 input channels and 5 output channels, but I wanna have 6 speakers with active crossovers.
You need one amplifier channel for every speaker if you want to run a truly active setup.
For good performance you would want to go with a 6 channel DSP or a 5 channel DSP if you want to bridge the subs in the rear, but still better off with 6 independant channels. Something with time alignment would be very good.
The best option is to have a deck that you can program all the crossover/time alignment settings with and send the signal to the amps. With all the HU's out there, I wouldn't see any reason not to get one designed with active crossovers in mind (6-8 independant channels) and possibly autotune/timealignment which is gonna save some headaches.
You could use those amps to independantly control the active setup with as few as two RCA outs but you would need a way to split the signal (with y connectors or an external DSP) and there would certainly be a loss in SQ. Most of the higher end decks now come with at least 6 independant channel outputs anyway.
680
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
A 6 channel and a single sub amp would be my choice. Or a 2ch, 4ch and a sub amp. You don't need 2 channels for subs.
968
Upgraded speakers in my 2023 EX X-line with the 4 speaker stereo, but it definitely needs an amp. The volume of this system is terribly low. My...
Rysandro
Rysandro
Orange County
West
audiobaun
    May 19, 2024
    May 19, 2024
