Yeah empirical data rules supreme, but I'm also not looking to predict actual real world performance here, and neither are you. The theory behind it all may be well off, but I'm still interested in hearing it. I'm sure those in the know would love to provide it with a nice disclaimer! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifI am sure you are going to get the worst answer for people like me and you....you have to test because it's application specific. I am sure you can model it for chambers, but then they would be worthless as your application would change the results.
I tried to request a model be build about predicting impedance rise, as the factors involed grew, I knew I couldn't model it to predict.
just keep adding to it. you can of course try to best-fit the T/S model to the system, but the T/S model won't show distortion.How so?How can you model it?
I can be if you plan to utilize them at full power.O, its that simple then? Well I guess modeling woofers at full power or excursion really isn;t too accurate then.
To an extent, the capability is there. Aside from the Klippel machines limitations with measuring inductance, it is great for measuring BL and Cms over stroke. Take a gander at some of the measurements done by npdang in the Reviews section over on http://www.diymobileaudio.com (and I imagine you'll find your answers better addressed there or on SSA than you will here, speaking in generalities).O, its that simple then? Well I guess modeling woofers at full power or excursion really isn;t too accurate then.
Great point.Though I am a big fan of designs that minimize odd order distortion, it is worth noting that even the most linear products are still occasionally poorly received. Drs. Earl Geddes and Lidia Lee have really been bringing this concept to light.
Alright capacity is there, but its not really an exact science (but then again, what science is exact when in practice).To an extent, the capability is there. Aside from the Klippel machines limitations with measuring inductance, it is great for measuring BL and Cms over stroke. Take a gander at some of the measurements done by npdang in the Reviews section over on http://www.diymobileaudio.com (and I imagine you'll find your answers better addressed there or on SSA than you will here, speaking in generalities).
If we can measure a driver's linearity and prove that there is little variation in BL or Cms over the range of our intended use, the small signal thiele/small parameters will hold truer. However, this still does not consider any thermal power compression, nor does it necessarily represent what will sound pleasing to the ear. Though I am a big fan of designs that minimize odd order distortion, it is worth noting that even the most linear products are still occasionally poorly received. Drs. Earl Geddes and Lidia Lee have really been bringing this concept to light.
edit - Something I often forget: I am looking at this from an engineering standpoint. For most customers that a company would cater to, the ability to corroborate any high-level testing is slim-to-none and, even worse, the desire to do so is extremely minimal. Your average consumer wants to go to BestBuy and buy what they are told is the best.
Through reading other threads on other forums, I've seen many people state explicitly that a lower Vas value implies a lesser Cms value. I cannot understand how this can be. If a smaller (comparatively speaking) number of moles of air is contained within 1 cubic meter, Ideal Gas Law states that pressure MUST be less than a comparatively larger number of moles of air (assuming constant humidity and temperature). I do not understand how the lower number of moles of air, with its lower pressure can posses a higher "spring constant" (Cms, with inverted units) than a larger number of moles of air. I can just look at a bunch of woofers t/s parameters and see that I'm missing something. Take Soundsplinters RL-S line for example. Cms value half that of Soundsplinters other offerings of the same woofer diameter, yet a TINY Vas value. What gives? What am I missing/not understanding here? Maybe some level of ambiguity in the definitions I'm using?Vas represents the volume of air that when compressed to one cubic meter exerts the same force as the compliance (Cms) of the suspension in a particular speaker.
The addition of the box amplifies the pressure air exurts on the cone for a given amount of excursion. its like adding more spring to the cone. this lowers compliance.Further reading on other boards as well as use of modeling programs has brought me to the conclusion that smaller enclosures increase system Q; they decrease effective dampening and make the cone a better resonator. Why is this the case? Comparing the effect of cone movements in two different enclosures of wildly different net volume, you will see that the smaller enclosure will have a much greater variance in internal pressures. This equates to greater restoring force on the woofer cone, especially during high excursion, high volume (high cone acceleration) playback. Why in the world would this create a system that stores energy better (once again, comparatively)?
Thanks
