Double thickness front side?
Braindead
I've been watching a few tutorials before i build my box, is it worth it to double up on the surface the subs will be mounted to?
Also I saw this one port idea, instead of having the port go off a right angle when it needs to go to the side (for more port length) have the extra length by putting another piece of mdf parallel to the first piece, and maintain port width? Anybody do this, is it worth it? I guess the idea is to not obstruct one of the subs with the port
depends on how.beefy the subs are ..and as far a a second wall in the port sometimes its neccesary sometimes not ..depends on what tuning u are trying to acheive
For my port i need it to be 26" long so i need a second wall, and my subs together are about 30lbs
Yea just make sure u maintain port width on the second piece ..and u dont need double.front baffle with that weight not even close ..i didnt start using.dbl bafle til i was running subs 35lbs each and up now my 12s are 64lbs a piece so i use dbl baffle with bolts and tnuts ..i dont trust any screw
Will it hold up if I build it with 2" drywall screws and titebond
Yes it will. If your cuts are good and you use enough glue, the screws are just there to hold things together until the glue dries.
But if you're gonna have to buy screws anyway, I'd use trim screws rather than drywall screws. They have smaller heads so they're easier to fill and sand smooth.
I only have 2 large clamps, should I just build it a section at a time? Im going to wood stain the box
Titebond II or III sets pretty quickly so I wouldn't worry with leaving clamps in place after the screws are in. And since you're staining the box, I presume you'll be using Birch or some other hard plywood? Stain and MDF do not work well together...
No, 3/4 mdf. I just though it'd look a little bit nicer with wood stain than spray paint. Could I just skip the screws or would that be a bad idea
Don't skip the screws. They're needed to hold things tightly until the glue completely cures.
And I would recommend not staining MDF, as it is not wood, it is wood fiber, wax and resin. When you stain it what you end up with looks like someone spilled a giant cup of coffee and didn't clean it up...
Yea dont waste ur time staining mdf ...just wont work...like putting lipstick on a pig..spend a few extra bucks and get birch or some cabinet grade ply
I made my cuts, and they don't line up too well. I dont have a belt sander, but would i use a dremel to even things up? lol
Braindead
Braindead
York, SC
bbeljefe
