double the subs sealed or ported?
wrathchild281
Hey guys I was planning on doing 4 10 hds310s in a ported box on 5k and I'm wondering if I should do 8 10 inch L7 's but sealed. Theoretically should they should sound about the same on the meter and would the 8 10s move more air? This is for daily setup, thanks
A lot of people rag on the l7s but I remember when they were king, they are not bad subs a little pricey as compared to those sq's. Why not run 8 of them? Or six ported if you have the room?
How if we're comparing it on the same power and the 10s have almost twice the cone area how could the 2 15s be louder
4 10s have 314 sq. inches, 2 15s have 353.25.
My guess is he was making this comparison. 8 10s would blow away a pair of 15s, though - obviously.
if you have the room to run 8 10s, you have the room to run 4 15s. However if you have the room to run 8 10s but only sealed, then a pair of 15s or 3 15s or even 2 18s would be a lot louder and lower in a proper ported box. Efficiency, excursion and motor force matters a lot. Sealed boxes are inefficient as hell especially with L7s in them.
Ya i got 6 cubes roughly so it was just enough for 8 10s sealed or 4 10s ported or 2 12s ported on 5k what do u think? Stick with the sq 10s I have?
With 6 cubes, go with the 4 10s ported, You wont have space for 2 15s. Port displacement takes up a lot of your sub's net breathable airspace. You might be able to do a triple 12 setup also but its still in smaller airspace then recomended. Either way, you'll need a lot more power to get them going properly.
wrathchild281
wrathchild281
Medford,OR
Jeffdachef
