Double runs
You need a 1/0 ground battery to battery. Stop using the body and frame.
I had dimming with a rated 1000 watts using frame grounds + big 3, but no dimming with battery - battery 1/0 with a clamped 4100 watts in the same vehicle.
so I need to make a run from front battery neg to back battery? I asked the question before and everyone said it wont make a difference...saves wire.
Well I'm already grounded to chassis with back battery. I have a bolt to frame inside and the other side has a wire to chassis...if that makes sense. Ill finish big 3 and do a negative run
Alright I will. By the way, is it okay to ground to the same spot on chassis for the engine to chassis wire, and neg. to chassis? Im using the stock location cause its looks to be good and ez to get to
Just got into it with some know-it-all but for a batt/amp combo. 1 pos run and 1 neg run from front batt to rear. Then from back batt 1 pos 1 neg run to amp. That should be all you need. Not to mention big 3 and alt and etc.
Bobby322
Bobby322
TX
Bobby322
