rogue 10+ year member
I am not a fan of that kenwood unit. The GUI feels cheap and by the time you add NAV abilities to it, you are upwards of $1500.
At that cost, you could easily get yourself an Eclipse Double Din unit. Eclipse makes amazing equipment. One of the best purchases I have ever made electronics wise was my eclipse CD unit. Their theft protection and warranty's are amazing.
The Output voltage is the only issue however. //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
AVN-2454 $1600 off ebay $1900+ from a dealer
GENERAL
Power Supply: 13.2V DC (11-16V)
Current Drain: 3.5A (0.5W)
Power Output: 50 watts x 4 (MAX)
Lineout Output Level: 0.8V (0dB)
Dimensions (W x H x D): 7-1/2 inches x 4-1/2 inches x 6-1/2 (180 mm x 100 mm x 165 mm)
MASS (Weight): 3.7 kg
Display
Display: 6.5-inch wide (16:9), low-glare panel
Resolution: 280,800 dots
(400 x 234 x 3)
Display Method: Through-type color filter
Panel Type: Color TFT active matrix
Brightness: 150 (cd/m3)
Drive System: Horizontal-shaped
cathode tube
System: NTSC
Screen Aspect Ratio: 4 types
FM TUNER
Frequency Response: 30-15,000Hz, +/- 3dB
Stereo Separation: 38 dB (1 kHz)
CD SECTION
Frequency Response: 20-20,000Hz, +/- 1dB
Total Harmonic Distortion: 0.03 dB (0 dB, 1 kHz)
EQUALIZER SECTION
Graphic Equalizer: 63 Hz ~ 12,000 kHz (1/2 oct step) +/- 10 dB
Also check out the AVX2494, which has a built in CD ripper and 20gb hard drive. You can find it for around $1300, but it doesn't have any NAV.
GENERAL
Display
(400 x 234 x 3)
cathode tube
System: NTSC
FM TUNER
CD SECTION
EQUALIZER SECTION
