Double Din install in a Ford F150
  • 2
F150Matt
I'm planning on getting an in dash TV for christmas maybe and I'm keeping the MP3 player I have now. I know u can fit two din sized receivers in the ford factory hole. The only thing is there is a slant at the top of the hole...I've been told u can cut this out or cut to slots in each side of it to make it like a flap. I also have been told to be careful, the EBS is right above the piece u have to cut. Has anyone done this before in an F150? Is there some sorta mounting kit I could use or do I just have to put them in there and they fit tight enough to work anyways? let me know. Thanks alot.
I'm by no means an expert at this, but as a 97 F-150 owner, after installing my kenwood CD player I realized that there is a track for the factory deck to slide in and out of the dash on, and it seems to me like it would be a lot of work to remove it. That is the reason most install kits have a shallow pocket above the cd player.
Sorry I couldn't be of any more assistance, just my 2 cents.
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
AGAIN sonic does the same install stuff for free as well! Get a head unit with 4v preouts and 6 rca preouts as well they will be setup as front...
19
I didn't read the article, but with those GM Bose systems; either fix what needs fixing, or rip out the entire thing and start from scratch with...
7
Look at the JVC brand. I have an older unit with a removable face plate. Model KW-AV61BT. Contact Crutchfield.com support for some current...
Alpine HALO has a very nice display but lack remote control which I really miss more than I thought I would. I've been really into the Sony...
26
4K
F150Matt
F150Matt
Houston, TX
Jearod
Doxquzme
    Apr 28, 2024
Doxquzme
    Apr 28, 2024
Latest topics
