Double din install help
I tried those wires and checked the rest while I was back there and couldnt see any loose wires. I tried pulling on them to make sure they were all attached and everything checks out. I dont think its the speaker itself cuz I didnt touch them at all. Anyother ideas? It worked after it was first installed and then the next day it stopped working and only 3 work now
another test you can perform to test the speaker is to disconnect the two whit speaker wires and take a AA or AAA battery...found in most TV remote controls......then on the 2 white wires going to your door speaker not the radio touch one to each end of the battery...it doesn't matter which end...listen to see if the door speaker makes a scratchy sound...if so the speaker and wire are good...the tweeter at the corner of the dash won't make hardly any noise at all due to an inline capacitor 6db crossover that will filter the sound generated by the battery
Cbach1987
Cbach1987
Milwaukee Wisconsin
Cbach1987
