Double Din Indash
jeeper07
Rebuilding&Reconstruc ting
Does anyone have a double din that they can take mesurements of. im looking for the size of the outter ring of the screen. also the size of the part of the screen that inserts into the dash. also how deep the section that mounts in is. Thanks a ton if anyone can help me out. If you have one for sale and i can make this fit ill probably end out buing it from you.
awesome. like i said height and width of the face of the unit, most external edge. And then length width and height of the unit that is installed in the dash. thanks man
Got the measurements they are DECK=7" wide and 4" tall,SLEAVE=7 3/16" wide and 4 5/16 high.The depth is about 7" not including the cables attached so add about 1 1/2-1 3/4" to that to make up for the differance.
Hope that helps.
Yeah its weird the **** thing has like 1/4" gap between the top and bottom but it's pretty snug at the sides.I think its a cooling thing.The unit doesn't have an external brain so its all in one and I imagine it gets pretty warm.It does have some cooling fans on the rear but the gap is for curculation so it doesn't overheat.When you put the beauty ring on you can't even tell.Kinda throw me too when I was looking to do the install.
jeeper07
jeeper07
Indianapolis, IN
jeeper07
