double components?
jakl27
i have 2 sets of components by mb quart. q series 215.61q
stats per set are:
- 5.25" 2 Way Q-Series Component Set
- Impedance: 4 Ohms
- Frequency Response: 50-32kHz
- Power Range: 80-150Watts
- Includes: (2) Woofers, (2) Tweeters, (2) Crossovers and
all mounting hardware.
i have a single cab 03 f-150. i was planning to run on both sides
1-tweet in A pillar
1-tweet in door next to mirror
2 midbass in factory speaker door location.
would this be fine or is it a huge waste if i use both components. thanks.
well i already have 2, these are brand new just havent used them in a long time as you can tell. just curious if two component sets will make a bigger diffrence then one set since its a regular cab. if i should only run one set is that all i should have for my mids and highs? or should i add a midbass?
You might want to try it using only one set of tweeters. Four Quart tweeters could get a little harsh. Sounds like a pretty good idea. If you have room for it all, go for it.
jakl27
jakl27
miami, fl
Eugenics
BP1Fanatic
BP1Fanatic
