Double Check My H/U Wiring...
Shelbrain
This is my first install and I was wondering if someone might be kind enough to check over my headunit wiring. I have a 2005 Chevrolet Impala and in order to replace the stock headunit you need this interface:
http://www.cardomain.com/item/PERGMCO
I will be installing an Alpine CDA-9830 headunit and am trying to mate the two together. I have connected red to red, yellow to yellow, and black to black. On the GMCO side, I am left with four RCA ends which I have taped off(for speakers), two orange leads and a blue lead. Do I not need these?
On the Alpine end, I have taped off all the speaker leads due to the fact that I am running new speaker wiring directly to the speakers from the amps, a blue power antenna lead, and a pink/black lead which the manual refers to as "AUDIO INTERRUPT>TO VEHICLE PHONE"
The part I wanted to make sure about was the blue/white remote lead from the Alpine harness is the one I need to run for the remote turn on. If I have two amps, do I run the one wire to the first amp and then splice the wire for the second amp?
Please comment if my wiring scheme above is appropriate. Should I tape off the 2 orange and 1 blue wires on the GMCO? Thanks!
run that Blue/White wire to #86 on a relay. have a CONSANT 12v go to #30. then a wire from # 87 to your amps, #85 ground, and #87a will be open.
wire it this way, because when useing 2 or more amps, it can be hard on a REM from the deck, thus over time can burn it out.
a little tricky, but better in the long run. look up a automotive 40amp Relay.
run that Blue/White wire to #86 on a relay. have a CONSANT 12v go to #30. then a wire from # 87 to your amps, #85 ground, and #87a will be open. wire it this way, because when useing 2 or more amps, it can be hard on a REM from the deck, thus over time can burn it out.
Agreed in principle, but there's no need for a relay until you're running 3 or more amps.
Typical Bosch relay coil draw: 150 mA. Typical amp remote input: >50mA.
A standard automotive relay will draw more current from the remote line than two amplifier remote terminals wired in parallel.
Shelbrain
Shelbrain
Florida
KaeZoo
