door speakers
most door panel's are usually the same principle either they have clips behind them and that pop's off the bottom and top part's but sometimes there are screws you have to take out where you actually hold to shut the door etc..... just look around im sure u will see what im talking about:).
yeah at first it is a bit strange.
I have 99 cavalier (chevy as well) and i have some screws at the very bottom of the panel, one in the panel for the side mirror (which is manual).
I don't know if this helps but this is what i do:
1) Unscrew all the screws in the panel. That way you don't forget to if you do one at a time.
2) Take off the side mirror panel (if you have one, i have to do it because it holds the main panel on if i don't)
3) Take off the window crank!! (should you have manual windows) Don't lose the clip! Its tiny and springy!
4) Pull on the panel and it comes off.
Then your done. Once you get used to it, you can take it off very quickly.
playboiij
$Georgia Bulldoggin$
playboiij
GA 229/BAMA 334
konechiwa
Mike Mccabe
