Door speakers cutting out when I connect the amp.
I haven't bought a wiring kit so I just grabbed an electrical wire from a lamp and clipped the ends, could this be the reason why?
//content.invisioncic.com/y282845/emoticons/omg.gif.05aa02c3095d6ce9338996654eca0863.gif are you for real?? that's the funniest $hit ive read in a while....//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
how did you connect the lamp wire to the battery? just wrap it around the terminal ?... //content.invisioncic.com/y282845/emoticons/omg.gif.05aa02c3095d6ce9338996654eca0863.gif
ok i discoonected all my back and front speakers from head unit so far i try hooken the back only to the amp but almost their i can hear music with the rca cable only then i connect the back speaker to the amp and then from the head unit wire back peaker i connect only one wire and its music i didnt connect both head unit wire because when i do that it turn off or their no music at all my amp ligh turns on on the short?the only one wire i think its the positive i only connect so that the music can be hearing true its weird is it? if i try connecteing both + , - it short off and my short light on my amp turn on . but i have gotten a lil closer to fixing it their something im doing wrong? am i suppost to connect the speakers>>>amp>>>> head unit? like this?
im almost certain he has the stock wiring from the headunit still connected to the speaker. you should now have only 2 wires connected to each speaker. (positive and negative from the AMP only)
you should have no wires running from the head unit to the speaker
rca- head unit to amp
speaker wire - amp to speaker
thats it!
I was using lamp wire for the grounding, not the power.
Was finally able to fix this after shorting out 3 head units. lol. I was wiring the coaxial speakers to the head unit. I now have the RCA cables connected to the headunit and from there to the amp, and the the coaxial speakers wired to the amp.
South Bay
