Don't want to get ride of stock HU.
  • 6
chevypwr
Since my truck is the base model work truck, I want to keep it clean and simple without any chrome or neon dials. I just upgraded to a Delphi CD player currently found in the LS model silverado's. I actually like the clean look, and it fits like it should. My question is can I still use this HU? Some kid said I can't build a system with a stock one, My brother said theres an adapter or somthing I can use. Who's right?
attached is my new head unit
There are a few ways you can go about doing this...If you just want a subwoofer, you get get a Line Output Converter (LOC for short). This will give you a set of RCA preouts for an amplifiers input. Then all you would need to run are power and ground cables, and a 12v switched wire. If you want to upgrade you door speakers, you can do a few things...
Direct swap out with Co-ax speakers/components
Use a LOC to run a front stage amplifer, and amplify your mids.
Or go all out and purchase an OEM interface like the JL Audio Cleansweep, or Rockford Fosgate 3sixty.
There are a ton of options with an OEM HU.
1 2 3 4 I declare a thumb war, 5 6 7 8 with this hand I mahsturbate.
977
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
These would be my options for a single DVC4 sub wired to 2 ohms.If you decide to run another sub later of the same as a pair for a 1 ohm load, I...
Coulda already had his answers (4) My interior dome lights are dimming with bass | DiyMobileAudio.com Car Stereo Forum
20
chevypwr
chevypwr
tampa, florida
pickup1
