Does Guage Matter?
yoshima123
Ok. i have the alpine mrv-f545, i like it a lot. i just went ahead and used my 8ga wiring from my last 4 channel amp. When the amp is on i get 13.2V on the display.
which i think is decent cosidering i have a civic. i have blown 50amp fuses.
Is my amp wanting more?
is upgrading to 4 ga. worth it with my car, since the alt. is small?
will a 4ga give it more amps?
will it sound better? better S/N (even though its good)?
thanks
Just use 18 gauge, it'll smoke a little but that just means its "breaking in".
Seriously, whats the rms ratings for that amp and what does it have for onboard fuses.
well if your amp draws enought current it will proceed to melt the plastic coat on your power wire and cause an electrical short on your car now your honda ECU wont like that at all so go to town and get the 4awg wire and be safe. nobody likes electrical fires.
I'm running around 1.7kW off of 2awg, and that's about the most I'd comfortably do. I've got a 200A fuse underneath the hood.
1/0ga for 1.8kW should be fine, unless you're running very inefficient amplifiers.
38
493
10
yoshima123
yoshima123
Dallas, TX ( arlington )
cjjackson85
