does ****** fluid affect engine performance?
noob with an RS
i poop on you
hey my buddy just got a brand new Infiniti G35 and his brother-in-law said that he should change out the transmission fluid because the factory transmission fluid is thin. he said that using better transmission fluid could give up to a 5-horsepower gain. is this true??
but if infiniti didn't put synthetic in, would u say that changing it to synthetic could yield some performance gains? the thing is my friends bro-in-law is very experienced in rebuilding engines.. but he specializes in mainly toyotas and hondas.. but i wouldnt doubt him.. so assuming infiniti didn't put synthetic in, would u say that changing it to synthetic could yield some performance gains??
if it did, the performance gains would be unnoticable ( like sending 550 watts instead of 500 watts to a sub) But synthetic fluids can greatly enhance the life span of an engine , transmission, and rear end. I use synthetics in everthing I own. I'll put it this way it won't hurt.
first off leave the fluid thats in there in it. infinity wouldnt use a lesser quality product on their car considering they are the ones that will need to fix it if it goes bad since it will be under warrenty. secondly he wont gain any power but what he may notice is smoother shifts but ****** fluid wont gain power its basically like saying putting different kinds of oil in a car will give it more power. all the oil does is keep things running smoothly and keeping things lubricated.
Well, that can be a touchy subject.//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
The final factor here is, he will not notice it. Even if the gain was infact there, dt loss would probably cut it down to 3HP, and if you can notice 3hp on a commuter vehicle then, well, wow.
that is a sweet ride, the ****** oil is the last thing i would be worried about if i just got that car.
and the transmission could be the first thing your replacing or having rebuilt. //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
noob with an RS
i poop on you
noob with an RS
earth
RandyJ
