Do you need to have a seperate chamber for each sub when going sealed??
  • 5
Supposedly separate chambers are better for some unknown reason. Usually common chambers are more efficient though and you don't have to worry about getting both chambers the exact same volume or whatever, so odd shaped boxes don't give you a hard time trying to split the volume in half exactly.
I used separate chambers so if 1 sub fryz I can still listen to the others. The walls inside the box for the separate chambers make good bracing.
That's what I was told to use separate chambers for. But honestly though, if you fry one of your subs, that's your fault, not the box lol. And ontop of that, who would still keep listening. I would replace the sub.
And on a side note, bracing isn't really needed in sealed applications, build very low SPL in relation to a ported box.
Shouldn't make a whole hell of a lot of difference unless you are running them off of more than one amp. Then you may see some cancellation if the amps aren't matched up perfectly. As long as it still is solidly braced I would just run them common chamber for ease of construction.I used to run four and then eventually six sealed tens years ago and never had any issues going common chamber.
107
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
94
432
335
743
Fuknmovin
Fuknmovin
Palm Desert, CA
Spooney
    May 12, 2024
Brendon Jenness
    May 11, 2024
